Greetings all, I've been having a problem with my 1971 125. In the past when we are underway, at planing speed it would momentarily stall then as quick as it stalled it would pick up and run fine. It might do this a couple of times or not at all. This weekend I brought it in the shop and I am not getting fire at the plugs. I have 12.54 dc volts at terminals # 8 & # 9 but when I do the power pack test where you ground the black lead of the tester and connect the red lead to terminal # 5 and crank the engine I get a reading of 0. would this indicate a failed power pack? If not any other suggestions? Thanks, Joho09
