I put my newly running (with help from this board) 25hp 1986 Merc on my jonboat and have found that the motor wants to turn to the left causing the boat to go to the right. I adjusted the motor on the transom so that it was centered and then even off center to the right to try and compensate (helped some but did not fix the problem). I adjusted the tilt pin so that it had the best plane, but know that the angle of the prop to the water surface can cause rotation of the motor. It just seems like the pull is more than what this would cause (I have to use quite a bit of arm strength to hold it inline). Any ideas? Is it worthwhile to try and adjust the anode to direct the prop thrust? Any other tricks? I hate to tighten down the steering adjust screw to near locking to to try and fix this.
