Re: Pulling my 87 5.7 mercruiser engine
Ok! getting close to pulling my engine, here's my pre engine pull list, if you guys notice anything I didnt disconnect but need to please chime in.
Removed the out drive.
removed the fuel line
removed the 4 lag bolts from the motor mounts
removed the 2 long bolts that hold the engine to the transom housing
removed the water coolant hose from the transom housing
loosened the screw clamps from the y pipe to the engine
disconnected the alternator to battery cable
disconnected the trim sensor wires from the engine
disconnected the starter cable
diconnected the shift cables and throttle cable
disconnected the ground wires
disconnected the power steering lines
disconected the ignition plug from the engine.
I think thats everything?
You forgot a few things. Ill update your list for you.
Crack a beer
Crack a beer
Crack a beer
disconnected the shift cables and throttle cable
disconnected the ignition plug from the engine.
Crack a beer. Put engine on stand. High five and breath sigh of relief.
