Pulled the boat out while still running about 5 minutes
miner85
I pulled my boat out of the water yesterday but forgot to turn it so it ran about 5 minutes out of water. No alarms went off. What should my next steps be.
Replace the impeller and anything else you discover that you wrecked once you pull the lower
gm280
Friction is a terrible thing. Without water lubricating the water pump impeller, it is probably toast. 5 minutes is a heck of a long time with out water cooling the engine. You probably removes hours of running off the engine life span...
