Hi All,
think of this as one of them "identify the tool" type contests (except I think its a part from somewhere in the outdrive)
Hoping maybe someone can shed some light here... Doing routine maintenance, just cleaning stuff up and tinkering around my 1998 Volvo SX outdrive (attached to a 3.0L). Took the anode from the gimbal housing (to clean the zebra muscles from the anode) and a small "shaft" fell out. It was in there loose and I have no idea where it may belong/come from. 3 1/2" long, about 1/8" diameter, chamfered ends and appears to be stainless steel. Has wear patterns on it like it might have been a "hinge or pivot pin" of some sort. Hope this photo might help explain more.
I'm completely at a loss... Any help to find where it should be is appreciated. Even if you can make suggestions for possible applications and I can check to see. I'm not use to having "extra pieces" left over!! Wondering if it might have been one of those "crap! I dropped it... now where the frig did it go??!" type pieces from someone else (a prior owner) when having service done and just never found it (but hopefully replaced it... )
