pull starter
fleng
I recently purchased a boat the starter does not want to engage when pulled 2001 Johnson 15 hp model j15rvsic it shifts lockout works but when in neutral does not engage , Am I missing something, Some times it will engage if I shift reverse to forward a number of times but now no.
Vic.S
Sounds like the pawl is damaged or sticking.
(Shifting a number of times probably a red herring)
Remove the whole starter assembly to access the pawl but don't remove the central screw or the spring will escape like a caged tiger ........ nearly as dangerous as a tiger but more difficult to get back in because you cant entice them in with food.
The manual on the boatinfo website may be of help http://www.boatinfo.no/lib/evinrude/manuals/1990-2001johnsonevinrude.html#/528
The pictures are not good but OK if you zoom in on them
