PULL STARTER ASSEMBLY CAME APART
wedotops
I have a 1977 15 hp johnson sea horse outboard motor model 15R77M. Upon pull starting (in the middle of a lake) the bolt that holds the pull starter assembly decided to come off. Well this caused that long medal winding wire to unravel. does any one know where I can get a schematic and some suggestions on how to re-wind and re-assemble this thing? thanks
JB
Re: PULL STARTER ASSEMBLY CAME APART
I would suggest a Repair Manual, Wedotops, or a qualified repair facility.<br /><br />That spring is very hard to reinstall, and dangerous if it gets loose when under tension. Experienced wrenches, following the Manual, can do it with little hazard. Getting that experience has cost me more than one scar.<br /><br />Good luck. :)
