Justinde
- Dec 11, 2010
- 431
Ahoy Mateys
I uncovered the beast today ( by the way, it's 27degrees CELCIUS today, and, oh, NO WIND) so I am frustrated!!!
**Background**
The battery ran dry as the tilt/trim was in the up position, ALL NIGHT.
**Update**
Charged Battery, started after a couple of goes, but the PTT sounds like the battery is DEAD- buzzzzzzzzzzzzzzzz- you get the picture.
I took the top off the PTT to expose the motor, and it spins freely. I put more fluid in- by the way, the manual calls for 30w engine oil, which I topped up with- but it has red pneumatic oil in it. What do I use?? I read that Pneumatic ATF/PSS fluid are a no no??
Tapped on the rams to see if they were stuck. Backed off a line, and the engine lowered, so rams are OK. Enginbe holds in up position- valve OK.
I replaced the relays, and put the motor back on the PTT, and now I dont even get a buzzzzzz, just a relay gouing nuts. Relay buzzes and buzzes.
Put old relays back, boat wont even start now. I went backwards at 10000MPH.
I am thinking that I have an electrical problem ( der), but the initial PTT being stuck in the up position- would this cause the PTT engine ( electrical motor) to seize?
Secondary is the relays. I bought new ones, connected them ( same numbers on pins) and got a GREAT spark when I reconnected the negative to the battery. Now the entire engine is dead.
By the way, I don't seem to have ANY fuses other than circuit breakers, in the boat.
Over to you.
By the way.......
HHHHHHHEEEEEEEEEELLLLLLLLLLLPPPPPPPPPPPP
I have another few months of this weather!!
**Background**
**Update**
Over to you.
By the way.......
