ProV bass fuel sending unit
bradmurd
Hey there
I’m running a 2020 2075 ProVbass bench style with a 250hp ProXS. Late last year It seemed either I was burning significantly more gas or my gauge may have a fault. This spring I changed the plugs, fuel filter and regular oil change, tank was full before I winterized. While idling noticed my smart craft gauge and my analog gauge would slowly decrease fuel %. I went out for a short ride where before my needle would barely move if at all and now it goes down 20% or so. My gph at 30mph are around 6.3-7.0 which is normal in my experience.
I’m wondering if anyone knows the exact location of the fuel sending unit as I am thinking this could be faulty giving me poor gas reservoir readings. Unless someone here suggests something else to look into..?
I read someone had an experience where when they used SeaFoam it affected their float. I use seafoam every fall before my last trip of the season
Any help or direction would be greatly appreciated
airshot
Been using Sea Foam for over 20 years with no issues like that. Sending unit is in the tank or attached to the top of the tank. Uncover the tank or follow the hoses/ wires and fill hose....you will locate the tank and fittings. No one said it will be easy, usually lots of stuff to move out of the way to reach the tank. Often they are under the floor, not sure with your model.
