Re: protecting a trailer
Hi Sikpper Dan, about the only guaranteed way is to lock the trailer in the police station garage. However, thieves generally like to quickly grab and steal something, so, if you make it difficult they will look some where else. One simple trick is take an extra ball and cut the threaded portion off, then lock it in the trailer hitch using a decent quality lock, don't forget to record and then remove the lock key code number from the lock or they can easily obtain a key and return tomorrow, thieves aren't all stupid. Ever notice the untended flashing message signs with generators used in construction zones, well, they have the same theft problem. What we do on long Island is put it on jack stands and remove the tires/wheels/lug nuts. Not fool proof, but makes it a lot harder and time consuming unless the thief brings a set of tires/wheels/lug nuts/wrench and a jack; same principal, make it time consuming to steal. Back in the 50's some Chrysler cars had reversed lug nut threads, so we used a combination of right and left threaded lug bolts and nuts, drove the tire thieves crazy as they loosened some and tightened the others, almost as effective as razor blades under the fender skirts. Good luck, Ken
