Having issuessssssssss.<br /><br />Lowered the ...lower unit recently and replaced the impeller.<br /><br />Also rebuilt the carb...starts GREAT now. <br /><br />Started her up, no pee. Tried again, no pee. Shut her down after about 8 seconds on the longest try so it had plenty of time.<br /><br />Dropped the lower unit today, my only day off of course hehe. I put a hose up to the intake and sprayed, water pee'd out the top.<br /><br />Was careful to check the old impeller to see what way the fins were going, and I think I had the impeller fins going backwards. So this time I was careful not to repeat my mistake, and reverse it.<br /><br />Put it all back together, then there was a shifting problem and had to drop it again to play with the shift tube. Put it together AGAIN, and finally started it up.<br /><br />Nothing but smoke comes out of the tube at the beginning, then no water...water is spewing out from every oriface on the sides of the shaft...<br /><br />Misalligned guide tube where the flange comes down over the water pump? Seems like this is a flexible tube and that could possibly get twisted up, and even tried to turn it but it doesnt budge so not sure if that could be it or not. But the flange SEEMS to be seating properly ontop of the water pump.<br /><br />Any suggestions? I have to take the started out and of course you know what else to drop this unit each time and would love to get it right so I could go onto bigger and better things hehe.<br /><br />(Mercury 9.9 - 1988 - 2stroke)<br />S
