props
gotsaved
1988 125 hp force will mercury props or any other props fit this force and does anyone know where i can find a cross reference for all props
WillyBWright
Re: props
The new Mercury props will fit just about any make of motor. You just need the right hardware.
montanaman
Re: props
The shaft should be the same as Merc. but it depends upon weather you have through hub exhaust or not. A good prop dealer with the proper selection of spacers and know how should be able to hook you up with a Merc prop. I believe that a Torque II hub with and OMC prop to fit it might be something to look at. Good Luck.
