Re: props and speed
Do you know your gear ratio?
While the Dolfin foil could help staying on plane and hole shot They can rob some top end and and in the extreme can cause weird
handling. I think your better off with something like smart tabs. They will help hole shot, help stay on plane better,keep the bow from bounding around,limit no wake speed wander and may even add top end.
Any tabs need to be added carefully , applied just enough to accomplish the desired result.
A 19" prop could lower the rpm as much as 400.If it revs too much with a new 17 you can still use it by watching the rpm
It will be peppier than the 19 and will stay on plane better than the 19.
