I will post this here due to an issue I've been having that isn't making sense.
I have a 1993 Merc 150 on a 19' ProLine center console. I run a 19 Tempest Plus for the best all around performance. I've been having a problem as of late and I wonder if I am cauing it by being overpropped.
When towing a tube, I cannot run in the midrange without having an overheat alarm go off. Idle to 2500 rpm is fine and over 4,000 is fine but you can't tow a tube that fast. So, 3,000 is the ideal rpm for me. However, the temp gauge quickly shoots up and the alarm goes off at that range. I don't have any handling issues, the prop never blows out or slips, the engine runs strong. Just overheats.
I have a 13 pitch Mirage that I have run in the past but have not put it on this year as it will over rev the engine at WOT. But it gives me awesome pulling power for tubes and is likely easier on the engine.
My question- can the 19 be causing the overheat? T-stats are good, poppet valve is good, water pump was done this year, water jackets are clear and it pees fine. All seems fine until I pull a tube. Your thoughts?
UFM82
UFM82
