All,
Apologies if this has been discussed, but I have searched this and other forums to find an answer and haven't found anything definitive. I'm in New England, about to settle in for the winter. Over the past few years, I have slowly begun doing all the maintenance on a 2015 suzuki df 250 outboard, and for the most part, it's easy. I am about to do the lower unit, oil change etc. for winter layup. Now, the very expensive yard where I used to have it serviced would inject a winter mix into the engine, but they never told me what they did, only that "the fogging oil will quickly burn off in the spring - no worries there." So my questions are: do I fog the intake? (I believe the answer there is NO), do I put oil in the spark plug holes and turn the engine over? (I believe the answer is YOU COULD, BUT NOT NECESSARY), do I run the motor on a mix of gas and fogging fluid, then shut down once it begins to smoke (I BELIEVE THE ANSWER IS YES, BUT HOW MUCH FOGGING FLUID TO ONE GALLON OF GAS?) Now, one interesting approach I have read is to add one oz of 2 stroke oil the the fuel water separator and run the motor until it smokes, then shut down. While that would be simple, I'm not sure it is the best approach. I am worried about the effect to the engine internal sensors. My plan is to buy a portable gas can, add the appropriate ratio of fuel to fogging oil, attach it to the intake on the fuel water separator, run the engine till it smokes, shut it down, then re-attach the gas tank line to the fuel water separator.
Opinions?
Opinions?
