I'm planning to winterize the a Yamaha F115 4 stroke motor myself this fall so this is what I think that I have to do. The motor is just out of the shop from the 10 hour breakin check-up (oil filter, oil change upper & lower) - and I expect to run another 10-15 hours doing fall fishing.
I'm interested in comments on what isn't right or what I'm forgetting...
Add fuel stabilizer & top off fuel tank
Change and internal gas filter
Change external fuel/water separator
Fog engine using muffs
Change engine oil & replace oil filter
Change lower unit oil
Pour RV antifreeze through upper flush fitting till it runs out bottom
Remove prop & grease spline
Plug fuel overflow vent
