I have only used my 1990 88hp Johnson OB a couple times. I flooded my motor when trying to start it at the dock. I turn my key to start it while pressing down to choke it. I pushed down every time I tried to get it to turn over. (about 15 or so tries.) Did this flood my engine? Is it actually choking the motor or priming it with gas??<br />Question 2: What is the small red lever on top of the mechanism (maybe the choke or primer mech) that is mounted just above the air intake cover in front of the flywheel??<br /><br />Thanks in advance,<br />Chris
