This post is in regards to a possible prop change on my 90 Yamaha.
Hopefully, answering the following criteria questions will help.
1) Performance issue you are trying to correct.
Need to increase RPMs to proper range and increase hole shot.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Not sure of manufacturer. I believe it is steel but it is painted.
3) Current prop diameter and pitch (required).
13" diameter / 21 pitch
4) Wide open throttle RPM and speed with an average load (very helpful)
4300 rpm and 45mph with 4 people, twelve gallons of fuel, two batteries and a 30+qt. cooler
Rises to 4800 rpm and 48 mph with 2 people, 8 gallons of fuel and same batts/cooler.
5) Engine/drive make, model, year, and HP
1987 90 hp Yamaha (90 ETLJ)
6) Boat make model, year, length and weight
1974 Starcraft American bowrider (FRP), 16'-3", 870lbs dry (no motor or gear)
I just purchased this motor and it performs very well overall. However, it does not climb into the recommended RPM range (4800-5500 i was told. OK?) at WOT. I am also looking for more hole shot for water skiing without sacrificing too much top speed.
Also, I don't want to break the bank, IE: Aluminum. I've seen the brands out there (Solas, Michigan wheel, etc.) but don't want to pull the trigger without being more confident in my selection. Local Yamaha dealer can get props quickly but I didn't know if the OEM props are guaranteed to provide superior performance.
Thank you.
Thank you.
