Steve Taylor
- Apr 1, 2001
- 3
I have a 1989 BassTracjer 17 foot bassboat with a 115 HP Johnson outboard. I have been experiencing some porpoising and high RPM readings at relatively low speeds. The engine is mounted so that it is at the lowest point on the transom mount (i.e., the top bolt holes). Underneath the motor is an aluminum wedge plate that is 1.5 inches thick at the top of the transom and tapers down. If I try to trim up past 1/4 trim I start porpoising and get the high RPMs. I installed a hydrofoil fin on the cavitation plate and it has help some. I think I need to raise the motor two or three holes. Any thoughts...before I pay $$$ to have a pro look at it??<br /><br />Thanks,<br /><br />Steve Taylor
