Mark42
- Oct 8, 2003
- 9,334
The GVW of my trailer is 1180 lbs. The manufacturer lists the trailer weight at 180. The total of boat(560), motor(180) and accessories(gas, battery, spare, etc = 150) is 890 lbs. That leaves me about 110 lbs short of the tailer limit.<br /><br />Should I run the tires at their max inflation (480 x 12 B) to get their max load capacity of 780lbs each? or should I run them lower to try to match the calculated load?<br /><br />If I run lower pressure, can I use the "flower on pavement" method of checking for proper tread contact? That is where flower is sprinkled on the pavement and the trailer is pulled through it and the resulting tire track is inspected for proper tread contact. <br /><br />Thanks,<br />Mark.
