Ragamuffin Man
- Oct 17, 2011
- 3
New to the forum. I recently purchased a 2003 Starcraft Starfish 18' pontoon, with a 2010 Merc. 4-stroke 60 (standard 20"). The shop that installed this motor set it as high on the transom as they could. When I try to trim out above 3000 rpm, it blows out at the surface, and loses most of its forward momentum. Could someone give me a guideline as to how many inches below the bottom of the transom the prop should be located? I'm sure it's too high, but the installation instructions that were in the ower's manual did not specify. I believe there are 5 stops on the vertical adjustment. Thanks.
