OK, here is the puzzle, please help me understand.
On my sailboat 9.9, 2002 exl shaft 4 stroke yamaha, I
use muffs after every run. Here is what I do -
Shut motor down, install muffs, turn on hose (low) start engine, allow it to get warm, disconnect gas line, allow engine to use all fuel, tilt up, remove muffs and then hose off the exterior of the entire lower unit, put canvas cover on power head and leave tilted up, completely out of the water.
My local Yamaha dealer had to remove the "exhaust cowling" and told me "it looks like it was never flushed EVER" "worst salt conditions we have ever seen".
Now my questions, 1. is it possible that salt water is entering this engine in some place other than the water intake ports that are just under the anti-cavitaion plates?
2. How would flushing the system ever flush out the inside of the lower housing? As I understand the cooling system, it is closed and the water that is picked up on the input, pumps up to the head and then out the "pee" hole. I always have a strong stream and actually check twice with the muffs on to be sure the water was not salt (yes I tasted it), I did that to be sure the muff seal was not allowing bay water in, because it can only be flushed in the down position. It was fresh.
Certainly, in the future I may switch to a bucket, but I always believed that muffs were good.
I don't have the built in flush port on the engine, and actually was told thet were inferior to muffs because they don't flush as well as muffs because you don't run the engine while using them - so the head does not get flushed as well as running it warm with muffs?
Don't know what I am missing here - but to me - if you take the lower cowling off and see packed salt, that is an area that cannot really be flushed?
** So, having thought about this more after I posted, here is the most clear way I can state my question:
If the exhaust system has failed, and no exhaust is coming through the prop at all, would water (salt) enter into the housing when the engine is being run (in salt water) with the fresh water muffs on? This is the only way I can explain how the engine appear to have never been flushed, when in fact it was flushed after every use? My thinking is that somehow, as the engine ran on the freshwater in the cooling system, that the outside salt water must have been being allowed in, through the inoperable prop exhaust openings? Any and all thoughts would be appreciated.
Thanks
Thanks
