proper battery selection
markdavid
I have a 40 hp motor and wanted to know what battery to use. I bought a deep cycle but it seems to run out if I crank the engine too long. Should I get a normal auto battery?<br />Mark
WillyBWright
Re: proper battery selection
Nope. Get a marine starting battery. As a rule I like to find out what the minimum requirements are for the motor and get the next bigger one. For yours that would mean a Heavy Duty. Typically you have Regular Duty or something like 24M-RD, Heavy Duty or 24M-HD, and Extra Heavy Duty or 24M-XHD. If you have a lot of other demand like lights, electronics, pumps, etc., by going to the next larger battery than the minimum requirement you have enough battery for everything.<br /><br />Most trolling motor batteries these days are dual purpose...Starting and Trolling. You might consider one of these as well. There are still single purpose Deep Cycle batteries out there, so make sure you get the right one if you go that route. Same rule applies to that kind of battery...next size larger. More than that is usually a waste and less may not be enough.
DHPMARINE
I'd recommend a marine "crank" battery.But if you are wearing down a fully charged battery of any kind,you have problems your motor should be up and running after 10 seconds of cranking at the very outside.<br />DHP
markdavid
The battery I have is a Wal mart, Everstart, Deep cycle marine battery. It says trolling on it and has 115 amp hours and 160 reserve capacity. Is this a dual purpose battery? As far as cranking for over 10 seconds that is a second issue to fix.
JB
Deep cycle batteries are not designed for the high current load of starting even a 40hp outboard.<br /><br />Either a Marine starting battery or a dual purpose is what you need.<br /><br />Cranking any battery over 10 seconds without a rest between is bad for battery life.<br /><br />Moving to Electrics.
kd6nem
I must respectfully disagree with you guys about deep cycle batteries not being suitable for cranking. It is all in being sized correctly. The RIGHT true deep cycle will outperform any other battery including the dual purpose everytime when it comes to long life and ability to withstand deep discharge. And sized right they compromise NOTHING except a bit of weight in some cases. Many mission critical vehicles- ambulances, police cars- are now using true deep cycle batteries for this reason. And our military uses them this way in all sorts of equipment including the Air Force fighter jets.<br /><br />I'm not saying the compromise or cranking batteries are bad, but few are the cases in which they are truly better than a genuine deep cycle. Especially the dual purpose compromise types. Their lower density lead plates are simply not as strong and durable as true deep cycle plates. The spiral cell type deep cycle can actually handle current levels as high or higher than typical cranking batteries, especially noticable when charging. Anyway, my 55 horse motors start readily with a deep cycle, and the batteries do just fine so long as I provide reasonble effort to keep water in them and keep them charged. (Neglect ages batteries faster than anything. Especially allowing them to be stored with a low or dead charge.)<br /><br />Long cranking does drain the battery, but even worse overheats the field coils in the starter. Then goodbye starter- perhaps later, maybe sooner. Never at a good time.<br /><br />My 3 cents worth...
