Is it normal for the propeller to spin while cranking the motor? I replaced an impellor and now this happening.
I have been told so many things about removing the lower unit that I do not know what to believe. Does the shift lever need to be in foward at time of lower unit removal or when it is put back together?
I was checking a no spark issue when the moving propellor brushed my leg. I will be posting questions on that issue later.
I have a Johnson Model 60ESL70B. It uses two solenoids for shifting instead of a rod. The battery was removed before removal of the lower unit.
Thanks
Thanks
