Re: **** Propellers ***** ??????
what are you looking for performance wise? top end, acceleration...ect there are so many things to concider when selecting a new prop. first, you need to have a tach so that when you do test your props, you will know if you are in the correct WOT rpm range or not. second, you need to find out what pitch the 2 and 3 blade props are so you atleast have a general idea of the pitch you are looking for. you will most likly not use a 2 blade, so the 3 blade would be best. third, how much are you looking to spend? you can get props anywhere from 120 dollars to 400-500 dollars. also, are you looking for aluminum or SS. you need to give us the most info you can in order for any of us to be able to give our suggestions on helping you find the right prop for your boat.
