Hello,
I have a aluminium boat which is approx 12 feet by 4 feet. I am powering it with an 8 hp Mercury Mariner as shown in the photos.The transom height is about 15 or 16" (the motor was in the way to get a perfect measurement). I weight 265 lbs and on the boat I have safety equipment and a 25 litre fuel tank. I am having trouble getting on plane.
I know that the boat has an easier time when I move forward to the middle bench which is why I put the fuel cell at the front of the boat. I took the boat out for a rip today and measured a top speed of 12.2 mph with my GPS. The boat typically seems to run around 10 mph just cruising at WOT. With only me in the back the bow is in the air enough that it obstructs my view, when I add a passenger to the front of the boat the boat is a bit slower (9 mph) but the bow levels off. When the boat manages to get on or near plane the bow is lower and everything is not bad. This is where the 12.2 mph appeared.
Yesterday, I felt like the boat was a little faster. When I was putting the fuel cell away today, I noticed that I had left the fuel vent closed during all of this so I will have to repeat it all tomorrow (darn!). I suspect this could effect things and also explains when the motor did not start first pull like it normally does.
Anyway, my main question after all of that is about this propeller. It looks pretty well worn out or at least it has a lot of rough surfaces and you can see that the black coating is bubbling off on one blade. Should I have this propeller serviced or replaced? Will I get better performance from repairing it as opposed to leaving it as it? Can anyone identify the part number stamped on it? I can't seem to find anything about it apart from it is designed for a Mercury motor and that the propeller pitch appears to be 8". The propeller listed in the manual for this motor is 48-828154A12.
Any help would be great.
