Propeller for 1983 Johnson 25hp
hercules25
What type of propeller can I use for my 1983-mod Johnson 25hp? (M#J25BALCTE)
trumpetbucks
Re: Propeller for 1983 Johnson 25hp
Hercules:<br /><br />The iBoats prop finder lists several "standard" choices for this motor. One of these should be a good place to start, but then it will depend on your boat setup and what kind of performance you get out of it.<br /><br />Here are your standard choices (all are three-blade props):<br /><br />9 inch diameter, 9 pitch or 10 pitch<br />9 1/4 inch diameter, 11 pitch or 12 pitch<br /><br />So that's four choices to start with. Might be wise to pick one in the middle. <br /><br />Good luck!
