Howdy fellas,<br />I've got a few questions about my current setup.<br />I have a 18' gulf coast with a Johnson 130 on it. <br />It looks alot like a boston whaler. It has a displacement of 1,200#'s and prolly another 400 or so with gear and persons aboard.<br />Port Side Picture, Stern Picture, and Stern 2 Picture <br /><br />My question is how fast should this boat run?<br />I've reached a max speed of 40mph @6,100 rpm.<br />The prop that is currently on there is a 13-3/4x16 as far as I can tell. I know it's a 16 because that is stamped on it. The dia I had to use a tape on. It's a four bladed and is stainless. The hole shot is enough to pitch a person out of the boat if they aren't holding on. <br />Would going to a 3 blade 18 pitch give me any more top end? The boat also has a jack plate to help tweak out the trim. I'm looking for a good spare prop that I can use on days when the bay is flat and I can put the hammer down. Any help would be appreciated. <br />Thanks, Hop<br /><br />P.S. I forgot to add, What props are interchangeable on this outboard? Will a prop off a 115 or 250 fit? I used a tape to pull a dimension from the shaft to the cav plate and i measured 9" so anything under a 17" dia should fit right?
