prop ?
CHAD DRAYTON
Hi I have a 1997 40hp merc on my 14.5' runabout and need to know what prop(pitch) is the best for it?. (has a 3 blade 11 pitch prop on it now)
Thanks Chad
Scout Sport Fish
Re: prop ?
Diameter?
What kind of boat hull?
What are you looking to do? Get up and out of the water quicker? More top end speed? More bite?
If its OEM you should proably just leave it.
Silvertip
Re: prop ?
To determine the proper prop you need to know what the wide open throttle RPM is with an average load. The difference between what the engine manufacturer recommends for WOT rpm and what you actually observe is what determines whether you have the right prop or not and which direction to go (up or down) in pitch. Without that data we can only guess. The 11P you have is probably close but on that small boat you could probably use a 13P. 50 HP motors (same displacement as yours) typically run 13P props on 16 - 17 foot boats.
