...I decided to try the prop wizard, for getting me in the right range for a new prop.
This prop is for a 1971 1150 Mercury (115 hp) fitted on a 19' Marquis closed bow. The hull is a semi-v. This motor has never ran on this boat before. There are no trim tabs, or PTT. I should be hitting 4800-5300 RPM for this motor. The gear ratio is 1.78:1.
The wizard recommended a 19 pitch for water sports and a 21 for speed. Does this sound correct?
