Prop wear question please
kitacooch
Hi there, i re-antifouled the boat and props 2 weeks ago, took it for a run on the plane for 30 min or so, later discovered a hull issue and so last week re- slipped it and noticed the props in this condition. Any ideas as to why they are like this be very helpful.
I did get as little cavitation when getting onto plane but only a little.
cheers
ohh and sorry wrong section, not sure how to move the thread??:redface:
steelespike
Re: Prop wear question please
You must be in salt? Sure looks like some sort of severe electrolysis problem.
My limited experience in fresh water is you don't normally put antifouling on the prop or associated hardware.
How long was it in the water.Any other work done at the time of the paint job??
Perhaps the wrong type of antifoulling.. Could be some sort of wierd electric problem on the boat or even in the marina or another boat.
kitacooch
Yeah is in salt, running 454's, was only in water for 2 weeks, run only once for approx 30 min on plane. Heard of prop burn but know nothing about it?????
steelespike
I think prop burn is the erosion of the surface of the prop in low pressure areas.
Caused by cavitation.
Nothing like you have.
kitacooch
been told it was ****ty/un-cured primer, will re-stip and re-coat.
cheers
