Hi
Need some advice. Have had some problems with a boat motor, a Mercury V6 135 hp from -88, I found that the linkage to the carburetors were loose and not syncronized so the motor was not running at full trottle. Found a service manual, made some adjustments, and the motor suddenly gave a lot more power. Now the prop sizing may be an issue.
The boat is a small english speedboat, (Fletcher) hull weight about 750 lbs. Length 16 feet, beam 6 feet 2". Motor weight about 400 lbs. Equipment 100 lbs. V-hull. Gear box 2,0:1. I ran the boat at a varm humid late summer day with a 2 person crew. Propeller Solas Amita aluminum 14,5" diam, 21" pitch. WOT for the motor is 5000-5500. I had problems with the tacho, probably a loose contact, but it was certainly above 5100 rpm and perhaps above 5500 rpm. GPS-speed was 42 knots. Hull was dirty with osmosis blisters, so it was running with some resistance in the water. I will fix the hull during the winter.
I have 2 propellers which I can test, but the question is if these propeller types are OK for this boat type? What performance can I expect from this combination of boat and motor/prop?
1. Stainless 23 pitch Laser-2
2. Stainless 21 pitch Solas HR Titan
Thanks in advance/Hansen, Sweden
