I have a 18' Smokercraft w/ 140 hp Mariner(79), just bought a new prop 13 1/4" x 17 deg. to replace a 13" x 19 deg. I was told this would make my boat run better at higher elev. I run anywhere from sea level to 6000 ft. I put the new prop on and checked the run-out, did not use a dial indicator but noticed that one of the three blades is approx. 1/8" to 3/16" shorter than the others. I know it is not a bent shaft, as I rotated the prop 180 on the splines and the problem followed the blade. My other prop blades were a lot closer in size/trueness. My question is: Is this a problem, or should I just run it and see if it has any abnormal vibration? Or should I take it back and get another? Thanks for the advice in advance. Stu.
