prop swap procedure
wizarddeath
90stingray
Re: prop swap procedure
Pretty straightforward ... shouldn't need the thrust washer, go ahead and use new nut and tab washer, and whatever your favorite marine grease is should do just fine. Just bend up the legs on the tab washer and hold the prop in one hand and loosen the nut with the wrench and your other hand. Easy stuff.
wizarddeath
Thanks a lot 90!
Sounds easy enough. Should I cancel the thrustwasher?
