Re: prop suggestion
It would have to be a very old prop to have no cup, and even if it didn't have cup, it should be close speed-wise to a 17 pitch (cupped), which at 6000RPM would be 45-47mph.<br />Your slip ratio figures out to be 34-35%-very, very bad, and I think we may have an indication (gauge) error. Either the tach or the speedo is incorrect and I suspect it's the tach based on the size and type of boat you have.<br />Before you spend any money on a prop, I would either have a shop verify the tach at WOT, and/or verify the speed with a GPS.
