Re: Prop stuck
HD, before you get the torches and saws out have you tried soaking the shaft/hub with a penatrating type lube? Liquid Wrench or even WD-40 may loosen it if you let it soak for a few days. Wet it a couple times a day and let it sit. After that you'll need a puller with claws to grab the lower edge/hub of the prop. If that doesn't do it it may pull the prop right off the splined hub. This will save you from having to cut through the prop. You'll be left with just the prop hub on the shaft, which will be allot easier to cut off and you can have the prop rehubed at a prop shop. Dunk
