Hello all,
Mercruiser 165 Pre Alpha drive.
In just doing some general fix ups of the motor/drive I have found that I can't remove the prop from the shaft. I have tried Wd-40 overnight soak, wood block and hammer from the back of the prop and heat from a propane torch.
Is there some kind of tool that one can use to remove the prop? Or any other ideas on the subject. I need to replace the water pump and I believe the prop must come off---Right?
Help, as always is appreciated.
Jim
Jim
