Prop spline length
Augie51
I pulled a corroded prop off an older Merc (finally, with liberal application of PB blaster, time and a fairly stout gear puller). After cleaning the crud off prop and prop shaft, it looks like the splines in the prop are only about an inch or so long while the splines on the prop shaft extend the full lenght of the shaft. Does that sound right.... only and inch or so of spline in the prop? Doesn't look like they were longer and corroded away..... not consistent. Thanks for any insights...
Texasmark
Re: Prop spline length
Times have changed my man and if your spline isn't stripped out, it must be able to do the job. Why are they longer today? Don't know. Maybe to accommodate a wider array of props that are available today.
Mark
