Hey everyone,
I will try to make this short and sweet for 30 years my father has had, and has run his 1965 21 foot trojan cabin cruiser. It has ~300hp 350 chevy in it.
the engine was rebuild and upgraded for this season. The old engine was tired and believed to be underpowered. With the old engine we were only seeing a WOT rpm of 3000. along with low RPM we were seeing a very high bow altitude.
with the new engine power isn't an issue. rpm will climb quickly to 5000rpm before WOT.
I expected with the more powerful engine that the boat would "get up over" this bow altitude issue, climb onto a better plane. This wasn't the case. The engine just revved up.
In the past I had heard of a quick and dirty test. Put a rope around the stern of the boat to provide lift. So I decided to string a piece of 3/8 rope around the stern.
The boat leveled out great, altitude was right where I would expect, and the wake looked much better. We were unable to try WOT with the rope because it would come off, but it was a successful test.
before the rope we were seeing ~12 knots @ 3000 rpm, and with the rope the boat ran much more level and almost 16 knots at 3000 RPM.
the configuration in the boat is a 350, with a 71c velvet drive 1:1, and a 13x11 3 blade prop 1" shaft.
im getting 45% slip, and that seems very wrong.
the boat is an lapstreak, plywood bottom fairly flat, 21 foot, 8' beam ~12deg shaft angle.
Is this all caused by a prop issue? The original engine was the opposite direction, but the same specs 13x11
any thoughts would be awesome.
with the rope, at a 16-18 knots cruise depending on the current, the boat is decent, but I would like it to perform much better if possible. The transom needs lifts, maybe trim tabs, or wedges on the hull?
Thanks guys!
Thanks guys!
