Re: Prop Slip Explanation
Yes the gear ratio has a great deal to do with it. Thats why JB used the prop rpm of 3000. A typical 100 hp outboard uses a 2:1 ratio. So JB's prop rpm of 3000 meant the motor is turning 6000. <br /><br />The weight, hull design, X dimension, prop design and more are all ingredients of the percentage. No matter how much a boat weighs, no matter what hull design you are working with, the path to efficiency is that percentage.<br /><br />No matter what rig you have if you reduce that percentage, that particular rig is more efficient. We use many factors to reduce that number like prop design (cleaver, round ear, over hub, thru hub, bow lift, stern lift, total lift, progressive pitch, progressive cup, total cup, cup length, rake, number of blades etc), hull design (V, deep V, pad bottom, notched transom, full tunnel, tunnel with a center pod, slotted V etc) gearcase shape and location, set backs, jack plates, trim angle and on and on.<br /><br />True, reducing weight will probably reduce the slip %. What if you cannot reduce the weight? Momma doesnt want to stay home or its a race boat that has to weigh a certian ammount. Many times just relocating the existing weight (change the center of gravity) will improve that %.<br /><br />Are we having fun yet?
