vissertrades
- Aug 16, 2003
- 79
Hi,<br /><br />Just got a GPS and went out testing different props. Link here has some background info (15.5' Smokercraft aluminum with '95 Johnson 50 VRO:<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=17;t=034497 <br /><br />Anyway, here are the results (me and 50lb son + 12 gal gas):<br /><br />1. Prop - OMC 11-1/2x19 Aluminum (new)<br />5600 rpm 33.5 mph.<br />2. Prop - OMC 11-3/4x17 Aluminum <br />5800 rpm 32 mph.<br />3. Prop - OMC 11-3/4x17 SS (looks cupped less than aluminum)<br />6000+ rpm 31 mph.<br />4. Prop - ?? 12x15 SS (heavy cup)<br />6000+++ rpm 30 mph. (almost jumped out of the water)<br /><br />I do have Smart Tabs installed at a 25 degree angle and actuator on weakest setting. I do have a OMC 11-1/4x19 SS yet to try. AV plate is currently 1/2" above hull and 19" prop vents easily in turns or from a non-straight take-off (breaks loose)...<br /><br />Here's my questions.<br /><br />Should this boat go faster? <br /><br />Is slip reasonable for a semi-V aluminum (18-20%)?<br /><br />What set-up should I chose?<br /><br />Should I put my beer down and slowly back away, ?<br /><br />Thanks!
