bonz_d
- Apr 22, 2008
- 5,276
Generally speaking looking to get an idea of how changing size relates to performance.
What I have right now is a 14' Lund with side console which Lund says weighs 285 lbs. Mounted on it is a 1978 35hp Evinrude with electric start. Total added weight, battery, gas, seats, and gear maybe another 150 lbs. So I figure total weight with 2 adults to be about 850 lbs.
The prop that came on the engine was a worn out 10.5 x 11 that had been ground down to about 9.5". It wouldn't push the boat, it would just blow out and slow down while reving up. I was able to replace it with a new 11 x 9 that a repair shop had for a very good price.
This 11 x 9 seems to work fairly well. Engine sounds like it is up to RPM at WOT and with this prop it is still very fast even with 2 adults and 2 childern onboard. Don't need to go any faster! But this set-up is very stern heavy and doesn't come out of the hole as well as I'd like and at mid throttle the bow rides vey high. At WOT the boat is very flat, on plane and almost too fast.
Surfing the web and the prop manf. sites I see that all seem to recommend either a 10 x 13 or a 10 x 15 for this motor and size boat. While the 11 x 9 is recommended for very heavy boats. So if this engine is up to RPM at WOT, which I'm still uncertain of but assume it's in range, what effect would changing the size and pitch have on this set-up and would going to a 4 blade prop be a better solution? If so what size range should I start looking at?
Hope this makes sense!
