Bought a 1995 Wellcraft Excel 19SX bowrider last summer (Approx. 2500 lb boat I think)...Engine is the 1995 165hp 4.3L Mercruiser with Alpha 1 drive...Boat came with a 14X19 pitch prop...We used it all last season and it was great for skiing but never goosed the boat b/c it would jump above the 4400-4800 RPM range recommended at WOT. I recently made the great novice move of backing into my deck and dinging up the prop. I bought a Michigan Wheel Vortex exchangeable system with a 14X23 prop. I figured this prop would get me down to the low end of the prop range and be great for early season cruising on the Potomac...Took the boat out Sunday and it is running right against 4800 RPM with 14X23 and hitting about 53mph trimmed out on smooth water. Can this be right or is my tachometer off? If the tach is right I should be able to turn a 14X25 within the RPM range?! I've never even seen a 14X25. Does anyone think a shop tach would be a good investment to check my boat tach accuracy?
