FreeBeeTony
- May 15, 2002
- 3,997
As most of you know I had a low RPM problem last year. At the end of my troubleshooting nightmare I discovered I was losing a cylinder at ~3200RPM. After removing the heads it looked like I was ingesting water (anti-freeze) in one of the cylinders.<br /><br />I replaced the heads and intake manifold with Vortecs.....gaining some HP.<br /><br />Question is what size prop should I be turning? I had a 15" on the boat when I had the problem, I am thinking of starting out with a 17".<br />Boat weights about 4000#.<br /><br />I may have already asked this question, sorry for the redundancy........
