prop size
rick powell
wanted to know if anyone had a sugguestion on what would be the best prop size for a 1986 Evinrude 200XP on a Ranger 390V. Right now running a S.S. Racker 4 1/2x 24 and at w. o. t. running 5000 rpm. not a very good hole shot.Should I also raise engine up to top notch, no jack plate.
rndn
Re: prop size
You need to get your rpm's up closer to the suggested 6000 rpm's. This will help your motor and also help with the hole shot.
