Yamaha F60 LTR 20" shaft, current year model, will be mounted on a older Mexican style panga 22' open, flat bottom skiff with remote steering.
Total weight, including boat, motor, fuel and gear should be around 1200 to 1500#.
These pangas are narrow in the stern and I am confident not designed for the additional weight of a 4 stroke, over an older 60-70 2 stroke which were common back in the days.
I do not have a need for top end speed performance and would be happy with a "all round" prop, as long as it allows the motor to reach it's maximum RPM of 5000-6000 RPM.
I am leaning towards a 4 blade aluminum, as my research tells me that style prop will give some "stern" lift....which would be a good thing I believe, due to the weight being mostly aft.
The engine selling dealer is suggesting a 6H5-45952-00-EL Yamaha OEM 10 5/8ths by 12" pitch 3 blade aluminum.
I live in Mexico and am 700 miles away from this dealer, so obtaining the correct size prop is imperitive the first time around.
Suggestions..........
