Prop Size Help
wburress
Trashed my prop today and I can't read the size on the inner hub. The boat is a 2000 Bayliner 1802 Capri cuddy cabin with a 2000 Merc 125 hp ELPTO. Four cylinder 2 stroke. I believe it is a 14 inch prop but I am not sure of the pitch. I did make out a 6 or a 9 on the inner hub. Any help on what I should order would be appreciated. I just want an aluminum prop like the one that is on there now.
steelespike
Re: Prop Size Help
Best solution is to take it to a prop shop and have it measured.
If I had to guess I'd pick a 17" pitch. Its not likely to be over propped and if under propped you can still use it by watching the rpm.
wburress
Re: Prop Size Help
Yeah I think I'll take it off and bring it down to the marina. Didn't have tools with me today. Thanks
