Re: prop shaft removal
Welcome to iboats.<br /><br />Without the proper tool, it's a tough job. If you're close to a dealer, take the gearcase to them. They might take it off for a tiny fee. Many will do it free if you get the parts there. Otherwise soak it well with WD-40 and use two big screwdrivers. LIGHTLY tap the outside of the gearcase around the ring nut with the hammer to help loosen corrosion in the threads. Heating the outside of the gearcase around the ring nut with a propane torch may help too. 180 degrees apart, hook the blade of each screwdriver on a cog of the ring nut and rest the shanks against the propshaft as close to the gearcase as possible and screw it out. You're using the screwdrivers as levers with the propdhaft as the fulcrum. Using 2 screwdrivers doubles the force you're applying. 180 degrees apart evens-out the force.<br /><br />DO NOT use the hammer and screwdriver to pound against the ring nut like a chisel. The material is soft and the ring nut distorts easily making it that much harder. If you must pound on it, lay the screwdriver with the flat side of the blade against the inner diameter of the ring nut and between two cogs, screwdriver parallel with the propshaft, and pound on the shank of the screwdriver close to the gearcase. That will keep the force parallel to the threads and prevent distortion.
