Prop shaft refitting question - '74 johnson 9.9, mdl # 10RL74 (long shaft)
Jim McClune
Upon removing the prop shaft for inspection, two ball bearings and a spring popped out. need to know where they belong/how to refit them when re-installing the prop shaft. thanks
Reel Appeal
Re: Prop shaft refitting question - '74 johnson 9.9, mdl # 10RL74 (long shaft)
Hi Jim,<br /> I think its time for that shop manual...<br />If you can't find one locally check out E-bay Auctions/CarsTrucksParts/Parts+Accesories/BoatsandWatercraft/manuals(in that order)Good luck!
Jim McClune
Thanks RA.<br />I know you're right about getting a hold of a shop manual - and thanks for the suggestions on where to find one. I was just hoping there might be a quick, easy answer to my question so I could use the motor for Labor Day. Thanks again.
