Re: Prop selection
I'm suggesting that a 14 3/4 X 17 is a good starting point.The next dia and pitch after that is a 14 1/2 X 19.Only a water test will confirm final selection based on the prop that will allow your engine to run at the upper end of its recommended WOT range.5500 with a light load is a good target rpm at wide open throttle.
